Finally added a lift kit!
Logan
Post by Logan » Mon Dec 13, 2010 11:34 pm
Just finished installing my 2 inch Overland lift kit. Very simple to do and only took me about 3 hours start to finish. :-)
before
after
1988 Astro Shorty full cargo - 350 TBI - 5 speed
1993 Passenger 4X4 Astro 305 TBI V8 -2 speed transfer case 5" custom lift - Built by Lockdoc
2015 Ram Promaster City - work car
2004 AWD Express 5.3
2005 Express 15 passenger 6.0
1984 Beauville Full Size Sport Van- built TBI 355-electric fans- 4L60e 95,000 original miles
2001 International School Bus
Re: Finally added a lift kit!
Post by timelessbeing » Mon Dec 13, 2010 11:56 pm
How were the front subframe bolts?
Logan
Post by Logan » Tue Dec 14, 2010 3:44 am
Really very easy to remove. They go into the Frame and the threads are not exposed so there was no rust issues or anything. I didn't even have to use any penetrating spray. Just the correct size socket and a breaker bar.
Post by timelessbeing » Tue Dec 14, 2010 7:19 am
Lucky guy. Mine seized with rust and ripped out the flimsy nut retainer, so I had to cut the bolt off. Then I had to pry off fender
sheet metal to get into the radiator support. )>)
Post by LiftedAWDAstro » Tue Dec 14, 2010 4:13 pm
That looks much better Logan. What did you do in the rear?
Logan
Post by Logan » Tue Dec 14, 2010 9:27 pm
LiftedAWDAstro wrote:That looks much better Logan. What did you do in the rear?
It already had a 2 inch lift in the rear when it's empty with the heavier spring and shocks. With the crap I carry, it would level out. :-) I just installed the lift shackles that came with the kit so they were a perfect addition.
timelessbeing wrote:Lucky guy. Mine seized with rust and ripped out the flimsy nut retainer, so I had to cut the bolt off. Then I had to pry off fender
Yeah, I wasn't so lucky when removing my trailer hitch from my 93. I had that happen. I just chiseled the bolt head off. #-o
loopie
Post by loopie » Fri Dec 17, 2010 6:10 am
Nice...do you go offroad?(or plan to)
I haven't seen those rims in quite a while.
Logan
Post by Logan » Fri Dec 17, 2010 2:40 pm
loopie wrote:Nice...do you go offroad?(or plan to)
I wouldn't mind going off road. But I do a lot of service calls in back road rural areas and some driveways are pretty bad.
Yeah, those rims are antiquated. They came on my 95 Astro and were all the rage back then. :-) The only reason I went with those is cause they had better tread than my stock rims and when it was time to get new tires, I didn't switch back. :-)
crash
Post by crash » Sun Dec 19, 2010 12:40 pm
hey logan.. any chance you could take a full on side shot pic and post it? it's realllly hard to see the change in the garage .. thanks!
Rob Image
current rides:
04 Mazda 6 V6 5spd
vans owned: Image
99 Astro LS Sept 08 ASV VOM
94 Astro LT
93 Astro LT
96 Astro LT AWD * parts van*
Logan
Post by Logan » Mon Dec 20, 2010 1:15 pm
Taken with my cell phone this morning. Hope that is better. :-)
crash
Post by crash » Mon Dec 20, 2010 1:38 pm
thanks! much better, looks really good!!
Rob Image
current rides:
04 Mazda 6 V6 5spd
vans owned: Image
94 Astro LT
93 Astro LT
