2005 with 2 speed tc ,4" lift
Safari gfx
Post by Safari gfx » Mon May 03, 2010 12:40 am
New project ,2 speed transfer case from a 2000 s-10 into a my brother's 2005 awd Astro, I also plan to use the front differential from the s-10. I spoke to a mechanic about this,he listed some different issues ,our parting words of confidence from him were "let me know how it turns out" I may have an issue with the connection between the 4WD mod and the PCM the astro for 4wd low.
2000 Safari GFX Limited Edition
awd,3.73 gears
Bridgewater,Nova Scotia
rlsllc
Re: 2005 with 2 speed tc ,4" lift
Post by rlsllc » Mon May 03, 2010 1:56 am
This could be and easy swap. There is a NP 231c T-case that was used in 1995 S10 blazers with a 5 speed trans (IIRC) that was a direct bolt in in place of the NV136 that is in your van. The drivshafts even fit with no mods. It is possble that the 2000 S10 used the same case, I don't know.
As for the low range, look here viewtopic.php?f=21&t=1940
or
1996astro wrote:Success! I wired a terminal in the number 23 cavity of connector 4 (Black). When switched to ground the PCM compensates for 4LO. The programming is not needed. It now has so much torque without the front driveshaft when power braking the rear wheels contact the wheel wells.
The front dif should work also, my 1991 Astro had a front axle from a 1991 S10 Blazer, and a cable from Posi-lock to pull it in.
Safari gfx
Post by Safari gfx » Mon May 03, 2010 9:50 am
Thanks for the info ,I knew that I was not doing anything new,I got to finish stripping the 2000 s-10 and get it out of there. I will be using the engine from the truck too,something real bad happened in the astro engine. I look forward to getting the van started. I think the astro are easier to work on,as for room,compared to the s-10,at least you don't have to root oil lines to the filter.
awd,3.73 gears
Safari gfx
Post by Safari gfx » Tue Nov 16, 2010 1:54 am
We have just added a 5.7 vortec to the mix,in the process of removing stuff from 1997 gmc 1500, :bounce:
awd,3.73 gears
T.Low
Post by T.Low » Tue Nov 16, 2010 4:28 am
So is it lifted now and you are adding the v8, or are you still in the planning stages for the whole dealio?
AstroLander Build Slideshow
Safari gfx
Post by Safari gfx » Wed Nov 17, 2010 4:42 pm
We are planning and slowly doing ,I still got to order kit from overlandvans,
awd,3.73 gears
loopie
Post by loopie » Fri Dec 03, 2010 10:30 pm
Looking forward to the build!
Safari gfx
Post by Safari gfx » Mon Dec 20, 2010 3:24 am
here's pic of my messy garage,this is my progress.
awd,3.73 gears
Safari gfx
Post by Safari gfx » Sun Jan 16, 2011 8:50 pm
we have have made more progress
awd,3.73 gears
Post by timelessbeing » Sun Jan 16, 2011 9:24 pm
It looks like it shat out out a bunch of bolts, and vomited up some wires hehehe.
Cool graphics though. :)
loopie
Post by loopie » Mon Jan 17, 2011 8:57 am
Such a tease you are!
