Terrain Tough Xtreme Ball Joints for my lifted 95
akforceten
Post by akforceten » Tue Feb 18, 2020 10:11 pm
Since I,m regearing the lifted 95 van from 3.73 to 4.10 gears I decided to replace my ball joints. In my search, I found these on RockAuto.These ball joints look and seem to be tough for my lifted van
1997 RWD Astro
1995 GMC Safari 4x4 lifted 5"
akforceten
Re: Terrain Tough Xtreme Ball Joints for my lifted 95
Post by akforceten » Tue Feb 18, 2020 10:21 pm
here are some more pics of the top ball joint
1997 RWD Astro
Post by Captn. Crunch » Sat Feb 22, 2020 1:39 pm
Nice find- those certainly look burly enough. Let us know how installation goes.
Post by Herbie » Tue Feb 25, 2020 3:39 pm
Front ball joints on my 2003 was easily the most frustrating job I've ever done on any vehicle any time. I would rather attempt to rebuild the worlds most finicky automatic transmission on my dining room table than make another attempt at removing the factory ball joints.
Don't get me wrong, I'm glad I did the job (especially because now that they're bolt-in, the next set of BJs should be cake), but that was the most demoralizing failure of a DIY project in my entire life.
I am keen to see how these work. I went Moog on mine, but we all know that lifted vans eat front suspension components, so I'm sure this will be happening again soon...
Post by Captn. Crunch » Wed Feb 26, 2020 9:55 am
I can vouch for the lack of joy that accompanies stock ball joint removal. At least I didn’t suffer through mine alone as I did mine during the Torsen equipped cast iron diff swap with Rinny by my side. I’ll be making a note of these ball joints though.
timelessbeing
Post by timelessbeing » Thu Feb 27, 2020 6:21 am
the rivets were stubborn. A good drill bit with good technique will do most of the work. A good size sledge, drift, and and anvil will make short work of the rest.
Post by Captn. Crunch » Fri Feb 28, 2020 5:02 pm
After a bit of trial and error, I ended up using a small diameter grinding wheel to remove the rivet tops. A whack with a hammer and punch finished the job. After one or two I had it down to a couple of minutes per rivet.
On a different note: akforce... how does your van like breathing through a snorkel? Any drawbacks?
akforceten
Post by akforceten » Fri Feb 28, 2020 5:55 pm
it's ok I have to finish it one of these days
I modified the stock airbox the only thing I got left to do is connect the airbox to the snorkel
1997 RWD Astro
