1995-2005 UPGRADES - Engine, Suspension, and MORE!!!
dakleenupman
Post by dakleenupman »
Weblinks will be provided if any to provide. All information I believe to be correct. If in doubt, always contact manufacturer. I am not responsible for anything related to this information whether it be wrong part number or problems arising after installation and / or problems with the seller. All information is to be used at own risk. No Refunds....................................
1996-2005 4.3L ENGINE/ BODY MODIFICATIONS (unless otherwise noted)
The last part #’s on each line and/ or in bold designate most current info/ newest part additions from website as of 12/29/2006.
AIR FILTER OEM REPLACEMENTS
1) Holley Powershot,#221-1
2) K&N Filtercharger, #33-2225
3) Jet Performance, #4122
4) Accel Kool Blue, #KP2348
1) http://www.holley.com/HiOctn/ProdLine/P ... Chevy.html
2)http://www.knfilterchargers.com/search/appsearch.aspx
3)http://www.jetchip.com/
4)http://www.mrgasket.com/maincat.html
AIR INTAKE KITS
1) Volant, #25743
2) JET Performance, #63290
1)http://www.volantperformance.com/Produc ... /25743.htm
2)http://www.jetchip.com/
MASS AIR FLOW SENSOR
1) Granatelli, #350116 (normal intake)
2) Granatelli, #350116C (aftermarket intake)
1-2)http://www.granatellimotorsports.com/gm ... tm#PRICING & APPLICATION GUIDE
COMPUTER REPROGRAMMING
1) Hypertech PP3, #390202 (1996-1999) #360202
2) Hypertech PP3, #30001 (2000) #30024
3) Hypertech PP3, #30008 (2001) #30023
4) Hypertech PP3, #30012 (2002) #30012
5) Hypertech PP3, #30019 (2003) #30019
6) Hypertech PP3, #30022 (2004-2005)
7) Jet Performance, #2004 (stage 1)
8) Jet Performance, #2004S (stage 2)
9) Superchips GM Max Tuner, #2565 (98-00), #2575 (01-02)
10) Mach Performance ECM Re-flash, #UNK
1-5)http://www.hypertechinc.com/programmer.html
6-7)http://www.jetchip.com/
8)http://www.superchips.com/chevy_apps.html
9)http://www.machperformance.com/Main%20Page.htm
LOW TEMPERATURE THERMOSTATS
1) Hypertech, #
2) Jet Performance, #10171
1)
IGNITION ITEMS MSD
1) 6 Series, #6420 (6AL)
2) Wires, #32389 (98-00), #31649 (90-97)
3) Coil, #8231
1-3)http://www.msdignition.com/
IGNITION ITEMS ACCEL
1) Truck tune-up kit, #TST-1 (includes plugs, cap, rotor, wires – 9000 series)
2) Wires, #9044
3) Coil, #140024
4) Cap, #120142
5) Rotor, #130141
1-5)http://www.mrgasket.com/maincat.html
EGR MOD FROM MDW PERFORMANCE
1) EGR Restrictor Plates, #10GM9602, $74.99
2) EGR Restrictor, #44GM9602, $48.99
1-2)http://www.mdwperformance.com/index.html
THROTTLE BODY RESTRICTER PLATE MOD FROM CFM TECHNOLOGIES
1) Replacement Throttle Blade W/O Restrictor, #UNK
1)http://www.cfm-tech.com/catalog/gm_vort ... oducts.htm
INLET AIR TEMPERATURE SENSOR RELOCATOR/ SIMULATOR
1)Jet Performance, #61620
2) Radio Shack Resistor 4.7K Ohm, #271-1330
1)http://www.jetchip.com/
2)http://www.radioshack.com/product.asp?c ... 271%2D1330
THROTTLE POSITION SENSOR CONTROLLER
1) Casper's Electronics, #102017
1)http://casperselectronics.com/cgi-local ... uct=GMCARS
SUPERCHARGING
1) Powerdyne, #K10526-101
2) Mach Performance, #UNK
1)http://www.powerdyne.com/chevy.htm
2)http://www.machperformance.com/Main%20Page.htm
UNDERDRIVE PULLEYS
1) March, #4460 (2pc)
2) ASP, #841001 (2pc), #841051 (3pc)
3) JET Performance, #90105
1)http://www.marchperf.com/pg2.html
2)
ROCKER ARMS
1) SLP Engineering 1.6, #UNK
1)http://www.slponline.com/
SHOCKS/ SUSPENSION
1) Edelbrock IAS, AWD (1995-2005) – Front #3303, Rear #3438 ----- 2WD (1985-2005) – Front #3338, Rear #3438
EXHAUST SYSTEMS
1) Gibson, Dual Sport, #5607 (Aluminized), #65607 (Stainless)(2000-2005)
2) Gibson, Extreme Dual Sport, #5609 (Aluminized), #65609 (Stainless)(2000-2005)
3) Gibson, Split Rear, #5608 (Aluminized), #65608 (Stainless)(2000-2005)
4) Gibson, Swept-Side, #315560 (Aluminized), #615560 (Stainless)(2000-2005)
5) Gibson, Swept-Side #315500 (Aluminized), #615500 (Stainless)(1996-1999)
6) Gibson, Swept-Side, #315553 (Aluminized), #615553 (Stainless)(1995)
INTERIOR ACCESSORIES
1) Autometer Gauge Pods, #15123 (Single, A-Pillar for 2-1/16” gauge), #15122 (Dual, A-Pillar for 2-1/16” gauge)(1996-2005)
EXTERIOR ACCESSORIES
1) Lebra, Hood Protector, #45111-01
2) Lebra, Front End Mask, #55535-01
3) Auto Ventshade (AVS), Ventvisor (Plastic), 92006
4) Auto Ventshade (AVS), Ventshade (Metal), 12215 (Stainless) and 32015 (Black)
5) Auto Ventshade (AVS), AeroVisor (Plastic, wider at mirror area), #95015
6) AVS, Bugflector (coverage stops at ends of hood), #22001 (Smoke) or 22001-C (Clear)
7) AVS, Bugflector II (coverage wraps around corners of fenders), #24616 (Smoke) or 24616-C (Clear)
8) AVS, Headlight Covers, #41535 (4 light – 4 piece)
9) Kleen Wheels, Brake Dust Covers, #1507 (15”-5 spoke wheels, stock)
10) APC, Clear Taillights, #404113TLR (1985-2005)
11) APC, Diamond Headlights, #403662HLD (1995-2005, composite style)
12) IPCW, Clear Taillights, #CWTCE314C (1985-2005)
13) IPCW, Diamond Headlight Corners, #CWCCE19 (1995-2005)
14) IPCW, Projector Headlights, #CWCCE20 (1995-2005)
2000 Astro AWD
4.3L - 4L60E - Auburn Posi
Too many mods to list, NOT!!!!
ScottS
Re: 1995-2005 UPGRADES - Engine, Suspension, and MORE!!!
Post by ScottS »
Great info- thanks ! :cheers:
1998 Safari AWD NE OHIO
1995 Safari AWD
