Matt's New Shop
DISCUSS ANYTHING NOT RELATING TO ASTRO/SAFARI
IF YOU HAVE A PROBLEM, COMMENT OR COMPLAINT ABOUT THE FORUM, PLEASE POST IT IN THE FEEDBACK SECTION
Moderator: SoCalli V8
Re: Matt's New Shop
Post by mdmead » Wed Jan 11, 2012 5:27 am
Last Saturday, a crew came out and moved the gravel into the shop, spread it, and compacted it. I was out of town so I didn't get any pictures until Monday.
Notice the gravel poking out all around the perimeter.
And compacted on the inside.
The concrete guy called today and said he will likely pour tomorrow. Due to the low overnight temps, he will either blanket the slab or run heaters. Either way it is going to cost a few hundred bucks more, but I already knew that.
Re: Matt's New Shop
Post by astrozam » Thu Jan 12, 2012 1:34 am
How long a cure time in this weather Matt?
Re: Matt's New Shop
Post by mdmead » Thu Jan 12, 2012 4:06 am
astrozam wrote:How long a cure time in this weather Matt?
He said just a few days before I can use it. He recommended a week or so before I park something heavy (motorhome) on it. I will wait longer to put vehicles on it as I'm not in a hurry and want to make sure its good to go.
The pour was delayed until tomorrow... and it may be longer.
tbhager94
Re: Matt's New Shop
Post by tbhager94 » Sun Jan 15, 2012 3:39 pm
it is now sunday has the floor been poured???
2000 chev blazer 4x4
If its got tits or wheels, its gonna give you problems!
im sure we all know the #1 junk yard rule if it fits in your pocket its free.
Re: Matt's New Shop
Post by mdmead » Mon Jan 16, 2012 12:27 am
tbhager94 wrote:it is now sunday has the floor been poured???
Yes, it was poured. Pics to follow. (Out of town at the moment.)
peter
Re: Matt's New Shop
Post by peter » Sun Jan 22, 2012 11:56 am
Pics, damn you....
"Just keep swimming..."
97' 4wd Safari
ZZ 502 Ramjet
4"L"80E/NP241C
Ford 9"
Kinky is using a feather.
- Thomas Jefferson
tbhager94
Re: Matt's New Shop
Post by tbhager94 » Thu Feb 02, 2012 6:34 am
ok now your slippin, where r the finished pics???????????????????
Re: Matt's New Shop
Post by doyoulikeithere » Fri Feb 03, 2012 3:23 am
peter wrote:Pics, damn you....
:withstupid:
Re: Matt's New Shop
Post by mdmead » Mon Feb 06, 2012 2:24 am
Sorry for the delay. Been busy with other things, plus the concrete pour didn't go as well as it could have, and I wanted to wait until the issues were resolved before posting.
About the 16th of January was the pour. Guys arrived on site and did some final prep.
Concrete truck arrived mid-morning... which turned out to be the start of the problems...
Here's how the concrete was delivered into the building.
Instead of using wire mesh, the concrete is fiber-reinforced. Obviously this is a lot less labor-intensive. Since I'd never seen this before, I did some web searching and found it is a common practice. Guess time will tell how well it holds up.
As the pour was wrapping up, the equipment was cleaned up...
But wait... while it looks like these guys are starting the final finish work, there is still a section of concrete in front of the third door that hasn't been poured. Three truck's worth of concrete wasn't enough... They are now waiting on truck four...
The truck finally came, but the rest of the floor was already on its way. Here they are working on the last area that was just poured.
Looking pretty good overall.
Long story short, it got dark, and that last section wasn't smoothed as it should have been.
Due to the cold temps, the contractor set up a heater inside the shop to keep the temps up and aid in drying.
The next day, the crew was back to cut the concrete. The idea is to provide the places where the cracks will occur, since concrete will crack.
The heater was run inside for several days. During this time, I stayed out of the shop. Once the heater was removed, I went in to check things out.... and wasn't really very happy!
This is a big diesel spill where the heater was sitting.
With the heater sitting here, this section of concrete dried too fast and there is a hairline crack that runs through it.
And here you can see the swirl marks in the section of floor that was poured last.
If only one of these problems had occurred, I'd have probably just let it go. Maybe even two of them. And actually, it was the diesel spill that really pissed me off. I contacted Steel Structures, who in turn called the concrete contractor. He came out and made a few excuses, but eventually said he would work on the stain and the swirl marks. It took nearly two weeks before he actually came back and took care of things. The swirl marks still show a bit, but aren't nearly as pronounced. The stain was removed with an acid wash. (Obviously the crack remains. Actually, I noticed another small one too.)
I know my concrete will eventually have cracks, get stained up, and gouged. But I figure I ought to be the one responsible (at least for the stains and gouges)!
It's safe to say I'm not going to recommend this concrete contractor and if I ever need concrete work, he won't be the person I'll call. (And you know what, 99% of his jobs are probably just fine. Mine was kinda like the 'Perfect Storm' for him I guess....)
astroturf
Re: Matt's New Shop
Post by astroturf » Mon Feb 06, 2012 3:12 am
Matt,
I'm glad you got it finished.
May I ask what the floor thickness is?
Thanks, Jim
Re: Matt's New Shop
Post by 1Gary » Mon Feb 06, 2012 5:12 am
Matt given that ceiling height,over the yrs while you equip the shop,you really should consider a used two poster lift.Trust me bud,it just opens a whole other dimension on what and the kind of work you can do not laying on your back with a jack and jack stands.Just on the minor scale,think about wanting to change oil on your stuff and being able to lift it up on a lift.All the stuff you end up taking to a shop because of their lift and how much having one of your own would save.It could pay for it's self in acouple of yrs.Around here in Craigslist I have seen them from $800 to $2,300 used.I sure wish my landlord would allow me to install one.
T.Low
Re: Matt's New Shop
Post by T.Low » Wed Feb 08, 2012 5:49 pm
Matt, please continue to post pics as you organize the shop with the van and Bronco inside etc. That kind of stuff is better than anything on cable tv. :yawinkle:
AstroLander Build Slideshow
Cobra
Re: Matt's New Shop
Post by Cobra » Thu Feb 09, 2012 8:31 am
T.Low wrote:Matt, please continue to post pics as you organize the shop with the van and Bronco inside etc. That kind of stuff is better than anything on cable tv. :yawinkle:
I second that motion
Re: Matt's New Shop
Post by 1Gary » Thu Feb 09, 2012 9:04 am
Yepper-X3 :supz:
tbhager94
Re: Matt's New Shop
Post by tbhager94 » Thu Mar 08, 2012 10:04 pm
any updates
