hey guys help me out here
Major projects, rebuilds and overhauls covering multiple areas
k120189
Post by k120189 »
...hows this look for my first bite into modding the van?
--->2000 RWD 4.3L/4L60E ,3.43 gears.exhaust and throttle body mods.
...gone =(...
-->1998 kia sportage 3 inch lift 30 inch tires under repairs
Looks like a good bunch of work for you! The only thing I would recommend changing is the tranny cooler. The stacked plate style are about 30% more efficient. I recommend a Long True cool LPD4590. This will drop tranny temps around 40 degrees.
Been thanked: 2 times
Post by astrozam »
Project time! and like Dean previously mentioned the stacked plate style works more efficiently and stands up to road debris better, hope you have a digicam, cause I smell some PICS.
I've had mine on now for 4-5 yrs and it still looks in great shape
skippy
Post by skippy »
Theres a set of 2" drop spindles on ebay for $180.00
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
DAILY THOUGHT:
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
k120189
Post by k120189 »
well its gonna take a few weeks to get the cash i just started senior year of high school and im starting a new job soon...but as i get the money the van will get parts...i think the drop is the last thing to go in...after all that i save for a shift kit and a v8.
...gone =(...
SafariRob
Post by SafariRob »
I'm going to break ranks with my brethren here and give a thumbs up to your transmission cooler selection. The one listed above is very similar to the one I have installed in my 89 and it does a very good job for the money. I rarely see trans temperatures above 175F even in the hottest weather we've had (but I also have a deep transmission pan installed that adds 3 extra quarts of ATF. I'm sure that also helps to keep the temps down).
One suggestion: I'd recommend that you look into a way of adding the transmission cooler without attaching the cooler directly to the van's radiator core via the supplied plastic ties. I can see where road vibration could cause the cooler to rub against the radiator fins and cause damage. I built a frame out of aluminum angle that the cooler attaches to; there is no contact between the cooler and the radiator. But I don't have the A/C condenser on the van anymore, so there's room for the cooler frame that wouldn't be there otherwise.
Now, concerning the tach. I see that its scale goes up to 11,000 RPM and that it reads in odd increments. I'd suggest getting a tach that reads no higher than 8000 RPM--this type of scale spaces out the lower RPM markings and makes it easier to read at a glance. It's the lower RPM readings that your van's engine will be at. My van also has the 3.23 ratio rear and the engine turns 1700 RPM at 60 MPH; it's rare to see a tach reading of 4000 or higher unless I'm really beating on it. Even then I've never had the engine turning at 6000 or higher; things just sound way too busy for me at an RPM like that.
But finding a 2 1/16" tach with these specs isn't easy. I ended up with an Autometer 2 1/16" Artic White tach--it reads 0-7000 RPM, but it cost about 3 times what the tach you listed does.
Don't get me wrong, the Summit tach will work fine for you, I'm sure. But there will be a lot of unused gauge that'll restrict the space of the used area.
Rob Shaver
PharmAstrocist
Post by PharmAstrocist »
Good prices on the DJM stuff. Same ones I have I think I paid a little bit more at godfathercustoms.com .
Where is that site you're buying from?
Krispy: '90 Astro Cargo Shorty ----------------------Newest Addition: Kremey: Stock '99 Astro LS 8 Passenger, New CD/MP3 w/ 10" Woofer
Lowered
Rimmed
Kitted
Wired for Sound
ImageImageImageImage Krispy&Kremey
k120189
Post by k120189 »
thats summit racing....the kit is in two parts the flip kit and then the 2 in drop spindles....they have the drop springs too, and yea its cheaper there in two peices then it is in most places together
...gone =(...
