Pro street LS1 98 Astro
Re: Pro street LS1 98 Astro
The difference in V8 traction from weight transfer between the Shorties and the Stretch body is dramatic too but it probably isn't as clear with those meats on the back.
'04 White AWD Astro cargo
'00 Astro / El Camino
'61 BSA Super Rocket
Stan-with a four link and instant centers,you can negate the over hang of the extended van's and really use it to your benefit like ballast.
Finished the exhaust & exhaust tips. At cats 2 1/4 to 3 inch with Flowmasters, to 4 inch oval tips.
85 pro street Astro, parted & scrapped
98 pro street Astro, 33x22 rear tires, all aluminum 335 hp LS1 motor
PRO STREET 4 LIFE
PRO STREET 4 LIFE
Just curious.I looked back on the thread and you don't have the info on what rear end you are using and what is the gear ratio??.
I hadn't checked in on this thread in awhile... WOW! I'm impressed! Really nice.badassastro wrote:Think I will be raising the rear up a whole, about 2 inches, could use some rake
But I'm thinking more like an 1" down in the front and an 1" up in the rear....
I'd leave it just as it sits. It looks great. Nice job.
Thank you Smilesafari
Thank you mdmead. Would look good another inch down, but its lower than it looks. I have to be careful with stuff hanging down, oil pan, deep extra capacity tranny pan, 3 inch exhaust and some of the rear framework.
1Gary: It has a 9 inch Ford with 4.10, pretty close to stock rear with 3.73. The rear has Detroit Locker, Richmond gears and Moser axles.
PRO STREET 4 LIFE
PRO STREET 4 LIFE
Put most of the interior back in.
4 bucket seats with racing harnesses and seat bases painted to match exterior
installed dash pieces painted to match exterior, still need to do glove box and overhead console
made tunnel for gas filler tube, had to recut panel and carpet. still need to carpet tubs and tunnel
PRO STREET 4 LIFE
PRO STREET 4 LIFE
Very cool compliment, Thank you timelessbeing
PRO STREET 4 LIFE
PRO STREET 4 LIFE
Did i miss it or did you never show the LS1 part of this build?
got any info on what pan you used headers things like that?
I bought the Astro from hpbystan, with the LS1 already swapped in. Stan gets the credit for doing the swap. For the price of buying it already done, saved me alot of money, hassle and time. I am so happy I bought it and decided to transfer all usable parts from other to this Astro. In the long run, the decision will save me a lot of money.
It still has the stock manifolds and cats. Not sure on headers, would be nice, but not needed.
At the moment, drawing a blank on the pan, will get back to ya.
Here are the pictures of the swap:
http://s1132.photobucket.com/albums/m571/mikehaaksma/
Cleaned it up and took better pictures
PRO STREET 4 LIFE
PRO STREET 4 LIFE
Carpeted tubs & gas filler tunnel
retrimmed & installed rear panels
Added safety items
Painted 1:18 scale to match full size Astro. I plan to make 1:18 scale pro street rims & tires fit it, kinda like a Mini-Me.
Added safety items
PRO STREET 4 LIFE
PRO STREET 4 LIFE
Too cool!
