Starting my build
Starting my build
Post by Captn. Crunch »
Hey
So I love my 99 AWD and have been figuring out what I want to do to my rig. So far I have modified my rear end by installing a zexel Torsen rear differential. This gets me from an open diff to limited slip/posi track. I have also done the 2" body lift and S-10 rear leaf spring swap. I have put on a set of wrangler 29" tires and started swapping out the front end parts with Moog components.
I have picked up an np236 transfer case and the associated computer parts to control it. I will be rebuilding to case here shortly before installing. I will use the exsisting encoder motor for the time being to maintain AWD and work on accessing low range a little further down the road.
I have found and posted here a limited slip option for our 7.2" front diff. Jeff at Engineered Performance needs the center chunk out of the diff for a week or so to modify it to a LSD. Not wanting to take my DD off the road I thought it best to buy another front diff. While surfing other forums I became aware of a very cool piece of GM history. If you bought an S-10 4x4 with a manual five speed and the three button np231 transfer case your truck came through with a cast iron front diff vs the aluminum that came in everything else.
For the last year or so I have been checking the national used parts registry for one of these. They are rare and expensive. Last week I tried again and a yard in Pa. quoted me $250.00 shipped so I bought it. That's half price compared to previous quotes!
I will be sending the center chunk to Ga. for upgrading and installing this cast LSD in my van. This will give me power to all four corners. I then have to start a slow methodical addition of electronics to incorporate the two speed transfer case with the auto four wheel drive option. I haven't taken any pics of what I've done so far as its all been documented on this forum already. Once I get into uncharted waters I will keep you updated with lots of pics till then...
Stroverlander
Re: Starting my build
Post by Stroverlander »
Sounds like fun and looking forward to your progress reports!
I keep an eye out at the salvage yard for a ZR2 iron front differential but haven't come across one yet, great find! Is there website for Advanced Engineering and where are they located in Georgia?
www.engineered.net/
Engineered Performance - Home of the EP Limited Slip Differential.
You visited this page on 6/17/14.
Sorry my bad I gave the wrong name. This is the place.
photo_van
Been thanked: 3 times
Post by photo_van »
Sounds good Captain. Aren't those front ends used in the Bravadas and syclones too?
Sy/Ty's all came though with aluminum believe it or not. There is a poll over on zr2usa that runs down which trucks got the cast. Very select
http://www.zr2usa.com/mboard/index.php? ... howforum=4
photo_van
Post by photo_van »
thanks for that link!
So I checked the tracking number for the diff and its sitting eight miles away for the long weekend. That's alright because I have plenty to do with the ball joint re-location, torsion bar crank and the np236 transfer case rebuild.
Small step backwards today as my ac compressor seized up and smoked me out of the van. Thankfully no flames. Buddy had a spare and we were back up in an hour
Stroverlander
Looking forward to the NP236 rebuild and install as ultimately, this is the direction I want to go as well. :cheers:
I was re-reading my post and noticed an error. The combination of five speed manual transmission and three button 4x4 np231 transfer case should read np233. My apologies
Here's pics of the cast iron front diff and an np136 and np236 side by side
I picked up the two transfer cases because I have not been able to find any side by sides to put to rest any doubts the 236 is a straight bolt up operation. Both cases have their own small issues so I will be taking both apart side by side and constructing one good case with hi/lo range. I will initially use the encoder motor from the 136 and if all is well I will have exactly what I have right now-AWD. The next step will be to start swapping in the two speed electronics and start trying to access the low range.
The cast iron front diff is from a ZR2 S-10 so it has the 3.73 ratio already in my van. The center chunk is going to Performance Engineering for a limited slip upgrade. Then a front diff swap. I will use the two piece S-10 axle to maintain the power to only one wheel for road manners especially in low traction situations like snow. I can engage the fourth wheel with the pull of a cable to power up the fourth wheel for extreme traction situations.
photo_van
Post by photo_van »
Wow, those cases look identical. Are they both five bolt bolt up with the same clocking? (Assuming that later Astros are 5 bolt....)
Hope it works out, probably a lot easier then what I had to do with a '98 for AWD!
It appears the only difference is the one speed/two speed. The cases appear identical in every way. I will be opening them up and all will become clear
photo van your transfer case build was inspirational dude! That was some great build
photo_van
Post by photo_van »
thanks Cat'n. Looks like a cool project. :cheers:
