ADDING REAR HEAT
Chase1
ADDING REAR HEAT
Post by Chase1 »
what do we need to do to get rear heat in 1999 it has rear A/C thanks for the help.
Been thanked: 9 times
Re: ADDING REAR HEAT
Post by Astrophysics »
Well , some items include extra extra valve and T fitting up front to connect into heater hose circuit.'
Long run of rubber hose under vehicle, drill hole thru floor
Rear heater radiator unit that is located under left side of 2nd bench seat.
Dash switch to select rear heat.
Etc.
The detailed diagram should be in full shop manual.
Lots of work.
Maybe better to get down jackets and comforter and wool blankets.
Chase1
Post by Chase1 »
thank you
markinnh
Post by markinnh »
Best thing to do is hit auto salvage yards pick n pulls till you find a gen 2 van with rear heat and swap it into your van.
always tinkering with stuff
Chase1
Post by Chase1 »
ok thx
