Try statewidelist.com for your searches.
Allows you to search CL by state and get all the listings for your search in that state. I have also found this site to pickup vehicles for sale that are overlooked by other search engines. The fewer search terms you use the better your results.
I un-check the search titles only box and CHECK the results in a single list.
Much easier to review.
Try it you might like it!
On the hunt for a Unicorn (2005 AWD astro/safari )
- I am merely driving my van
Re: On the hunt for a Unicorn (2005 AWD astro/safari )
Mike
"Drive Fast, Turn Heads, Break Hearts"
1987 4WD Astro
1987 4WD Astro
Doesn't the 03-on come with the upgraded spider injectors? Or did they come out earlier?LiftedAWDAstro wrote:The only differences between the 1999 - 2002 and 2003 - 2005 vans is that the 03 - 05 vans have rear disc brakes, 6 lug axles, 16" wheels and they seem to have either stiffer or more arched rear leaf springs. Other than that they are identical. I personally prefer the 02 and older with the rear drum brakes. They are much more reliable in our area due to all the salt and sand they put on the winter roads.
I was in the same boat a few months ago. My 96 AWD had sprung up a pretty bad lower intake gasket leak, and was overall pretty well worn out. I was on the hunt for an 03+ to replace it. Couldn't find anything remotely close by for a few months, so I took a few weekends and replaced the LIM gasket, front end, rebuilt the steering gear, and got new tires...
I still find myself looking for the unicorn if it ever pops up. If only the right one shows up locally...
1996 Astro Awd - All stock, soon to be lifted and camperized
1998 GMC Safari 2wd - Work van. 258k miles and counting
I would way rather find another 1987, 4.3, 5 speed shorty in really good shape.
Found a Safaridoyoulikeithere wrote:I would way rather find another 1987, 4.3, 5 speed shorty in really good shape.
http://missoula.craigslist.org/cto/5464388703.html
