I know it's bad form to get right into it without an introduction but.....
I am looking at a 99 Astro and need to know any common problems to look for.
You could at it like this, give me some good advice and gain yourself a new member.
She has 108K and felt good on the test drive today.
I was able to look around underneath with a flashlight and all looked fine based or age mileage.
Thanks in advance.
When buying a van (99 Astro awd) what to look for?
Re: When buying a van (99 Astro awd) what to look for?
I tested my AWD in the gravel before I bought it to make sure the AWD system worked. Try tight turns to see if there is any kind of binding during the turns. Check for same tire size front to back and even wear.
I had to replace my radiator but that is not uncommon with any vehicle of that age. Your Mileage is real good.
Some of the other common things that have failed on my 99:
Window regulator motors
Front door lock actuators
Front hub/bearing
Front door outside handles
None of these would keep me from buying the van you are looking at. All problems listed and more can be solved be searching this site.
Front hub/bearing
When I bought my '99 I did notice some orange 'goop' around my starter, but thought nothing of it...later learned about the lower intake gaskets and realized it was where coolant had been dripping down the motor...check for coolant leaks
"BOYCOTT AUTOZONE!"
I would pull the engine and transmission dipsticks and look closely at the fluid color, feel and smell. Make sure they are at level and the engine should't be real thin, cloudy or smell of gas. The transmission should be a dark pink to a red color and not smell burnt. If it's dark brown to black, expect to have to rebuild the tranny at some time in the near future. Look at the front and rear diff's for oil leaks and also the engine oil cooler lines. Find out when the idler arms were last replaced if at all. If they have never been done, they will need to be done at some point.
Depending on price, the only deal breakers for me are 1. the tranny fluid and condition and 2. the engine running condition. The rest of the stuff can be done with basic hand tools and a little time.
Thanks for the responses. I got the basics covered, been working on cars 30+ years.
It appear to have been owed/operated in/by NY city. Has a door sticker that says NY03?
It has a lot of Fleet RPO's.
Weird RPO code VSK that means "telstar"? I an assuming Telstar Automotive a conversion company.
It does have a old receptacle in that side and a few antenna mounts, maybe an old surveillance van?
will hear tomorrow if it passed PA inspection and then I may make an offer.
