1991 gmc safari dies randomly due to stereo?
IF YOU JUST WANNA TALK ABOUT ASTRO/SAFARI VANS. PLEASE DON'T POST TECHNICAL ISSUES IN HERE.
Moderators: Fire Cakes, Rileysowner
Derek939
Post by Derek939 » Tue May 28, 2013 4:17 pm
Ok so it has not happened to me yet but 2 of my friends have drove the van and said they came to a stop the radio cut out and made weird sounds then the check engine light came on and it died. But It fired right up and no issues after. The other instance my gf said she was on the freeway and the check engine light came on and started bogging so she turned the radio off and the issues went away. I have not experienced it yet and I drive the van a lot. Any ideas? It's only got a stereo from the 91 gmc safari tape deck that's the only upgrade I did so nothing fancy at all. Any help would be highly appreciated!
Thanks!
1991 Astro RWD EXT w/187000 miles
1991 GMC safari RWD shorty w/151000 miles
Runs off of Bacon!
The revolution of the Maing Bus!!!
Drummernaut
Re: 1991 gmc safari dies randomly due to stereo?
Post by Drummernaut » Tue May 28, 2013 7:34 pm
My first guess is something went wrong with your upgrade. Make sure you are tapping power from the Radio fuse or that your radio is connected directly to the battery with a fuse. Don't want to share power input with any modules or other systems.
Pull radio, look for loose wires.
If possible, observe your system voltage when the problem happens.
77bc
Post by 77bc » Wed May 29, 2013 2:22 am
How old is the battery and have you put a multimeter on the battery while it off and while it is running to see what kind of charge your alternator is putting out?
safari kev
Post by safari kev » Wed May 29, 2013 10:58 pm
my guess is maybe a failing alternator or battery. the factory radios from then are essentially plug and play.
00 safari high top explorer conversion. "shagfari" 235xxx miles on body. 242k on junkyard Jimmy motor.
94 safari hi-top explorer limited. 132k miles.
95 ASTRO choo choo conv. RIP @115K
97 safari slx "surfin' safari" 145k miles RIP
91 safari shorty Tiara conversion. RIP
86 cadillac fleetwood brougham. 67k. It thinks its a hot rod.
83 lesabre limited. 71k miles
66+68 toronados
66 Riviera
