Where to put 2nd battery for 110v converter or 12v cooker ?
General Discussion
( Please do not post help questions here )
trackvw
Post by trackvw »
I would like to put in a 2nd battery so I can run a 12v-110v converter or 12v cooking stuff.
it would have a heavy duty relay so it does not drain the main battery,
But where to mount it ?
Is there anywhere under the floor where I could build a "drop box" to store the battery in ?
or under the front seats ?
Ohh I may want to hook up a 12v winch INSIDE the van to pull heavy stuff into the back ( core motors to rebuild) , but thats another days question ?
Thanks for any ideas....or a 2x4 with my name on it if I do the wrong thing !
Been thanked: 9 times
Re: Where to put 2nd battery for 110v converter or 12v cooke
Post by Astrophysics »
West Marine sells an Automatic Charging Relay, ACR, which allows you to charge 2 separate batteries, e.g. Starter battery and House battery, independently without the 0.6 Volt drop of a diode based battery isolator.
AstroWill
Post by AstroWill »
There are a lot of places that you can mount an extra battery. If you are going to build a mount for it under the van just have to get under there and look to see where you can put whatever size battery bank you have decided on.
