96 Lifted, Locked, AWD, Safari in Tacoma
THIS FORUM IS FOR ASV MEMBERS TO POST ITEMS FOR SALE TO OTHER ASV MEMBERS
Moderator: Cobra
nonhog
Post by nonhog » Sun Sep 29, 2019 12:54 am
1st thing..... NEEDS ENGINE!
2" lift ,
Well maintained, clean, one small rust bubble other than that it is super solid.
Eaton Detroit locker
3.73 gears (tow package)
Custom roof rack
168K
5 alloys with ice rated Kumho tires
recent steering linkage, gear box and pump
Good front brakes
New rear brakes
New KYB monomax shocks
Have 4WD transfer case for you to install
Firm at $1500
Recovering hoarder
nonhog
Re: 96 Lifted, Locked, AWD, Safari in Tacoma
Post by nonhog » Fri Oct 04, 2019 4:11 am
2" lift ,
Custom roof rack
168K
Good front brakes
New rear brakes
Firm at $1500
(forgot to mention over $1000.00 in new parts included-not yet installed)
Recovering hoarder
Post by Captn. Crunch » Wed Oct 09, 2019 11:23 pm
Sooooo far away )>)
Bret Schmerker
Post by Bret Schmerker » Sat Oct 12, 2019 12:37 am
O:) 3.73:1 with an EATON® Detroit Locker® retrofit would be correct for the Hydra-Matic®/General Motors 4L60-E - I've got the same R&P on an open diff on my M11006. Down here on the edge of the Central Valley (CA, USA), I've researched a stick-shift retrofit and already decided on upgrade axles; I believe Curie Enterprises can build a High-Pinion 8 with 4.11:1 and EATON® TrueTrac® on the dropout carrier and Torino-style bearing retainers to fit a Chris Alston Chassisworks doubled full-length frame set for a K-1500 front suspension retrofit, which is easier for tire and wheel shops to dial in the camber and caster on (two eccentric bearing bolts attach the upper control arm to the frame) than the 4x2 frame, which needs shims on the upper-control-arm fulcrum attach studs. (The 4x4 has exposed double-U-joint shafts on both ends of the axle.) No decision on the front hub locks yet, but Currie can also build a 9" full-float dropout with unequal-length axleshafts (to match the 7.625" stocker's offset), 4.11:1 gears and TrueTrac.
