Removing door from salvage van.
The Mack
Post by The Mack »
I need to remove the passenger front door from a salvage van at the junk yard and was wondering what the best approach is as I know the spring is a concern.
I have a cordless sawzall.
I assume the pin is removed somehow?
Any insight would be appreciated.
TIA
1999 AWD Safari
2002 Astro
1996 Astro (sold)
WoodButcher
Been thanked: 16 times
Re: Removing door from salvage van.
Post by WoodButcher »
Look at a replacement pin at the auto parts store, pretty simple , once you see it up close you'll figure it out. 2 pins per door.
have a helper hold the door and you pop the pins, spring is not a concern coming out. Going back in,,,
Buy the compression tool. Six bucks?
'69 G10, straight 6, 3 onatree, jumped at me when I had a pocketful of cash looking for a spare astro. :)
Tools:
Small needle nose vice grips,
a long extension for a 1/4 drive socket,
Hammer.
Squeeze the clip with the vicegrip, use the extension and the hammer to tap the pin out while the vice grip squeezez the clip.
Dont even worry about removing the spring, you could just grab it with the vice grips, and pull, or if it isnt in the way, it will just fall out when you remove the doore. Like said, its putting the spring back that is a concern but can be done without the compressor tool. I have done 3.
The Mack
Post by The Mack »
Thanks guys, I knew I was over thinking it.
1999 AWD Safari
2002 Astro
1996 Astro (sold)
