I've got an '04 Astro with 16" wheels and I just got a full sized spare, 215/70/R16. Can the full sized spare tire go where the donut spare goes? The tire is on a steel wheel from a 90's Suburban.
One last thing, how do I get the spare tire holder down? I haven't lowered it in so long I forget how to do it. Thanks!
Full sized spare in the factory spare position; 04 Astro
Re: Full sized spare in the factory spare position; 04 Astro
oper the drivers side rear door.
Notice the small hole where you should insert the tool that should be stored in the same spot as your jack.
Insert the tool, and twist....
A full size spare should fit under these vans, unless its a shorty, like mine...
That's my problem, the rear barn doors don't open. Can it be lowered with the doors shut?doyoulikeithere wrote:oper the drivers side rear door.
The van did originally have a donut spare.
- Been thanked: 16 times
Drill a hole in the door in just the right spot,,,
In short, no.
You might want to fix that first.
In short, no.
