- wheels balanced
shocks have no weeping or "float"
repacked front bearings and tightened "snug"
upper/lower ball joints are new
good alignment
everything is greased/lubed
rear end is topped off
U-Joints have no play
chatter vibration above 65mph, what is it?
- Has thanked: 2 times
Hey guys, can't figure this one out. I jump on the freeway and get up to speed and chatter begins so bad my rearview mirrors vibrate so bad I can't use them. Here's what I checked:
1998 Astro, 246,000 miles
K&N air filter
TruCool trans cooler
K&N air filter
Re: chatter vibration above 65mph, what is it?
Well, I got home tonight and swapped in a new tail shaft seal. Hopped back on the freeway and still vibrates like crazy over 65.
The movement was vertical, but slight. Honestly, after changing the seal, I didn't recheck to see if it still moved in that way.
I'm starting to wonder if it's the rear end or axles. But there is no leaks back there, no noise, and nothing else to make me think it's bad. UGH!, so frustrating.
I really appreciate any help or suggestion, I'm stumped.
K&N air filter
K&N air filter
Is there a way to check rear bearings without removing the axles, wheels etc.?
K&N air filter
K&N air filter
both appear good. I took a jack and "lifted" it and no separation that I could see. Tranny mount is actually newer.
K&N air filter
K&N air filter
Pull the drive shaft again and move the u-joints through their range of motion. They should be free and smooth.
The second trans seal replacement might have to do with wear on the driveshaft yoke.A close inspection of that and if found,sometimes you can just emery cloth it and it will be fine and other times you just have to replace the yoke.I just dealt with that on my Sonoma.
Another friend just told me with his S10, he had a tranny rear tailshaft bearing go bad, same chatter resulted as I described. I looked at Autozone.com, but didn't even see this part he described.
K&N air filter
K&N air filter
Yeah that does kind of make sense given the rear seal issues too.If it was me,I would work a deal with a trans shop where I R & R the tranny and walked it threw their door to do their thing.
I had a violent shaking in the SPB after the first 4" lift and it ended up being the tail shaft bushing was bad. No bearing in there. Pull the cone off and you can pound the bushing out and press a new one in as well as a new seal. It only happened between 55 and 65 mph.
When you took the drive-shaft out, did you get it back in the same place? I seem to recall that if you don't get them back in the yoke in the same place they will vibrate. Take it out, rotate 180* and reinstall.
CD_S
1991 W41
1995 Astro - Now gone, I am Astroless.
1997 C1500
1989 9C1 Caprice
1997 Bonneville
1998 Olds 88 LS
http://forums.b-body.org - newly updated!
1991 W41
1997 C1500
1989 9C1 Caprice
1997 Bonneville
1998 Olds 88 LS
I have heard that too but I think it's a myth. The drive shafts are balanced on a machine and not in the vehicle. The machined parts in the tranny as well as axles and t-cases are all balanced by the way they are made. Plus the vibration was present before the drive shaft was pulled.
Yes, from my expereince a drive shat can be reinserted anywhere within the spline, does not affect rotation balance.
I spoke with a professional mechanic friend of mine and he seems certain it's my rear wheel bearings. This coming weekend, we'll pull the axles and take a look. I'll report back…
K&N air filter
K&N air filter
