No power on the fuse box for windows and Ac...
IF YOU HAVE QUESTIONS OR ISSUES WITH ANYTHING RELATED TO OBD-1 AND OBD-2, SECURITY, AUDIO AND VIDEO SYSTEMS, PLACE THEM HERE. USE THIS FORUM FOR SES LIGHTS, RPO CODES, FACTORY OPTIONS ETC.
madslammer
Post by madslammer »
Hi guys, Having an issue with the 87...
The terminals on the fuse box where the AC and PW connect are dead...
I made a temporary/permanent fix by connecting a jumper from the non switched 12v spare terminal...
I was told the problem could be a "fusible link"... If so, where is it located???
Thanks.
'97 Astro 2wd, lowered 4" w/Belltech spindles and drop leafs.
'87 Astro 2wd, lifted, pretty close to 4" all around.
v8famvan
Re: No power on the fuse box for windows and Ac...
Post by v8famvan »
Check for fuseable links behind the battery on the firewall
James from B.C.
1992 Safari - R.I.P.
GM Grand Master Techncian
