1999 astro dead
IF YOU HAVE QUESTIONS OR ISSUES WITH ANYTHING RELATED TO OBD-1 AND OBD-2, SECURITY, AUDIO AND VIDEO SYSTEMS, PLACE THEM HERE. USE THIS FORUM FOR SES LIGHTS, RPO CODES, FACTORY OPTIONS ETC.
Moderator: v8famvan
Chevyhulk
1999 astro dead
Post by Chevyhulk » Thu Oct 20, 2016 11:11 am
was driving along last week. back fired and died. replaced cap and rotor. and cam sensor under the cap.
got spark going into the cap but nothing coming out.
also don't have 5 volts at the ignition. i did the passlock override by connecting the yellow to the orange/black wire.
I'm completely lost. HELP
Mmusicman
Re: 1999 astro dead
Post by Mmusicman » Thu Oct 20, 2016 3:17 pm
Just curious... have you checked to see if you have fuel pressure?
Chevyhulk
Re: 1999 astro dead
Post by Chevyhulk » Thu Oct 20, 2016 3:40 pm
It stinks of gas. So I got gas. I don't have spark coming out of distributor
justice
Re: 1999 astro dead
Post by justice » Fri Oct 21, 2016 12:19 am
ignition module?
I have a ban hammer and I ain't fraid to use it!
Current - 2004 Astro Cargo
Former
95 Safari (money pit - sold)
93 Astro Cargo (totaled)
85 Astro - (Bought for parts and scrapped)
92 Astro Conversion (sold)
87 Safari Shorty (sold)
ihatemybike
Re: 1999 astro dead
Post by ihatemybike » Fri Oct 21, 2016 12:56 pm
Chevyhulk wrote:It stinks of gas. So I got gas.
That doesn't mean squat. If the pump isn't pressurizing the fuel enough, the vehicle won't start.
I've used pumps that wouldn't start the vehicle any longer to pump out the tank before putting in the new pump.
Replace with ACDelco/Delphi pumps only, unless you really enjoy replacing pumps.
Aaron
Prev Astros:99,97,00,94,87,86
Chevyhulk
Re: 1999 astro dead
Post by Chevyhulk » Fri Oct 21, 2016 3:30 pm
Ignition module is good. I don't have 5 volts at the key. That is the problem. Don't know why that is.
AstroWill
Re: 1999 astro dead
Post by AstroWill » Fri Oct 21, 2016 11:47 pm
Chevyhulk wrote:got spark going into the cap but nothing coming out.
So the coil is firing, but it's not getting to the plugs, sounds like you found your problem.
Chevyhulk
Re: 1999 astro dead
Post by Chevyhulk » Sat Oct 22, 2016 4:12 pm
The problem is that spark goes into the cap but doesn't come out. Now how do I fix that? Thats the real problem.
AstroWill
Re: 1999 astro dead
Post by AstroWill » Sat Oct 22, 2016 5:56 pm
If it has the proper wires going to/from the proper cap, through the proper rotor then it should be working fine. Something along those lines is non functional.
Chevyhulk
Re: 1999 astro dead
Post by Chevyhulk » Sat Oct 22, 2016 6:00 pm
From what I've read the passlock Alarm can kill a vehicle. Just died driving down the road
