How do I install an Anti theft switch?
IF YOU HAVE QUESTIONS OR ISSUES WITH ANYTHING RELATED TO OBD-1 AND OBD-2, SECURITY, AUDIO AND VIDEO SYSTEMS, PLACE THEM HERE. USE THIS FORUM FOR SES LIGHTS, RPO CODES, FACTORY OPTIONS ETC.
bunce1260
Post by bunce1260 »
I'm wanting to install an anti theft switch but I'm not sure how to go about it.
Is the fuel pump the best wire to interrupt with a switch? And if so can I just use a regular toggle switch on the negative cable?
Where can this wire be found? Im thinking of wiring under the van and going to a switch under the driver seat.
Any help will be much appreciated before we drive our van full of belongings from Chicago to Oregon in 2 weeks. Thanks.
2004 AWD. S10 4" rear springs. 2" Body spacers. Prothane body bushings. Insulated. Ventline VP543 roof fan. Hella 500's. Tru-cool 4454. Bilstein shocks. Brembo. Hawk.LED bar. 235/75/16 Hankook Dynapro ATM
www.instagram.com/vango_life
www.VanGoLife.com
Re: How do I install an Anti theft switch?
Post by Smiliesafari »
I installed a toggle switch that interrupts the fuel pump relay and the starter relay. You can hide the switch where ever you want.
bunce1260
Post by bunce1260 »
Hi Smilie.
Could you elaborate on how you did this? Im able to wire things up if I have instructions, but Im not electrically inclined to be able to just go at it. Thanks
www.VanGoLife.com
Really simple. I did it from the fuse/relay center under the hood. Find the hot wire for each relay and switch them. I combined both to a single switch.
Post by Captn. Crunch »
Smiliesafari wrote:Really simple. I did it from the fuse/relay center under the hood. Find the hot wire for each relay and switch them. I combined both to a single switch.
" find the hot wire for each relay and switch them" means put them on a switch and not to swap locations right? I was trying to figure out what good that would do :muhaha:
Ya..... I didn't think that one through. :rolleyes: #-o You figured it out. =D>
AstroWill
Post by AstroWill »
Pretty much you can switch anything that is a requirement for the vehicle running.
Or just take the battery with you when you leave. ;)
6spd_monte
Post by 6spd_monte »
I installed a switch in mine that will prevent the engine from cranking over at all.
I interrupted the power wire that runs from the ignition switch to the starter solenoid. Now, this is a pretty heavy wire so I didn't want to run it straight through the little toggle switch I had. I ran the starter wire through a 30 amp relay and used the switch to turn the relay on & off. I sourced the power to switch the relay from the fuse panel. Be sure to use a source that is hot with the key in the Run AND Crank positions. You can use a source that's hot at all times but beware, if you forget to turn the kill switch off, that relay will stay on and drain the battery overnight.
Anyway, I wired the switch into the ground circuit of the relay to switch it that way.
Easy-peasy.
-James
1987 LT
249,000 miles
