Speedometer No longer works HELP
- antispam: No
- How many wheels are on an Astro van? (4): 4
Re: Speedometer No longer works HELP
Cleared my codes and went for a drive. 1st gear only in D. I can manually shift into 2nd. If I return it to D, the trans has no gear. Absolutely no speedometer now. Re-read codes and get only C0265 which is an EBCM "No signal".
Past vans: 1990 2WD SLE Safari, 1990 AWD SLE Safari, and 2000 AWD Safari SLE. Current, 2004 Astro AWD LS.
- Site Admin
- antispam: No
- Has thanked: 2 times
- Been thanked: 2 times
I always check the obvious stuff first. Make sure the EBCM plug makes a good connection. Make sure it's getting good power and ground. Is your electrical system healthy (ie battery + alternator).
Then I would do the same for a transmission. (I can't remember if it's controlled by the PCM or if there's a separate module for it).
electrical schematics:
http://www.bbbind.com/tsb-wiring-diagrams-database/
More diagrams and component locators:
https://www.gmupfitter.com/pages/body-builder-manuals
- antispam: No
Thank you timlessbeing. I certainly appreciate your support and help! I tried to review as much as I could while under my van (I love my van). I found a Bank 1 Sensor 1 (front driver's side) O2 sensor with two wires rubbed through. I separated and insulated them. I found the source of a gasoline smell I've been trying to find for months (fuel filter). I placed the original VSS back into the T-case and went for another short drive. Speedometer at 100 but the trans shifted through all gears fine. Speedometer reset itself. ABS and SES lights still on. Another code read still shows C0265 and a Bank 1 Sensor 1 O2 Sensor fault. I'm tired and need to go to bed. I will investigate more tomorrow evening if I can. I would like to try to locate the ground wire for the EBCM.
- antispam: No
Wow! Thank you timelessbeing for the links. This is some really good information! I most certainly appreciate it!
- antispam: No
Sooo.....after repairing the exposed wires on the bank 1 sensor 1 O2 sensor, I took it for a drive. It seemed to work fairly well, but had trouble from 1st to 2nd gear. Drive it quite a bit. WOT to shift or very light throttle would also make it shift. That tells me the throttle position has an impact. Took it home and scanned again. Still getting a C0265 = EBCM Motor Relay Circuit code. Also getting a C0237 Throttle Position Signal Malfunction. Making progress. I'll try to get the TPS changed in the next few days and report back. I'll also be replacing the O2 sensor.
- antispam: No
Excellent work troubleshooting this issue!
Thank you for sharing the results.
My 2003 AWD has 133,000 miles.
I hope not to have similar issues for many more years. But, I will know about wiring issues.
- Site Admin
- antispam: No
Here are some TPS diagnostics ...
Symptoms of a Defective TPS
The 'Check Engine' Light is On
Bucking and Jerking/Hesitation while Accelerating
Idle Surging
Sudden Stalling of the Engine
Sudden Surge in Speed While Driving on the Highway
Testing
Test between blue and black wire.
.5v idle to 5v WOT
the readings should gradualy change hitting no dead spots
Or you can test with a ohms meter
TPS Actuator Arm at rest: Pins Values (ohms)
A to C = 5.88k
A to B = 2.44k
C to B = 8.32k
Rotating the TPS Actuator Arm: At Rest Rotated
A to B = 2.44k 8.26k
C to B = 8.32k 2.39k
Idle Surging
Testing
.5v idle to 5v WOT
A to C = 5.88k
A to B = 2.44k
C to B = 8.32k
- Site Admin
- antispam: No
... and O2
(typos are not mine
Symptoms of a Defective Oxygen Sensor
Poor fuel economy
Higher emissions
Stalling-Hesitation
Test
0.0 volts = Lean
1.0 volts = Rich
O2 sensor reading at the ECM to .450-.500mv when in open loop or the connector is disconnected.
ground the diagnostic connector and rev engine to 2000 rpm . The Check Engine light should flash once per second for closed loop operation and once every 1/2 second for open loop. It should start out in open loop and then change to closed loop and stay there.
If it flashes closed loop operation and then switches back to open loop operation for a few seconds. Check the O2 circuit for grounding out or poor connection. If that is OK then replace the o2 sensor.
if your getting a lean code this could point to a bad ground or poor conection
Knock sensor test
Parts store
the knock sensor produces its own electric currant. its very small but you can test for it. Set you tester to A/C probe the center of the sensor with the red lead and ground the black lead. now tap on the sensor it will produce 6-12 K hz
(typos are not mine
Poor fuel economy
Higher emissions
Stalling-Hesitation
Test
0.0 volts = Lean
1.0 volts = Rich
Knock sensor test
Parts store
- antispam: No
I have been out since my last post. I hurt myself and ended up in the ER and light duty for a couple of weeks. No further advancement on my Astro van. I will further diagnose it and update you guys during the week (I hope). I have yet to upload the squeak video to youtube. It's strange. The motor mounts and everything looks to be in good condition. I even let it idle with the brake on while I got under it (not in a position to be run over) and couldn't locate the squeak. It's puzzling.
- antispam: No
Wow! What a year so far. Wanted to update on my 04 Astro's status. Status is---the same. After I hurt my arm, we had area tornados Memorial Day weekend. Noting major. End of June, lost a very large tree. July, Car accident (not the Astro), and daily driver broken (again, not the Astro). Finally Starting to get back on it this week. Things have finally started to settle here (I hope). My first focus is the EBCM. I have had plenty of time to think about this one. We'll see what happens and I will update everyone with my efforts, results, and repairs for future group support.
- Site Admin
- antispam: No
Yikes ! Troubles are only supposed to come in three’s!!
Welcome back
Welcome back
- antispam: No
Hello again. About a year ago I was battling my 2004 Astro AWD troubles. I had a huge string of troubles (non-Astro related) that fought me that year. Those just kept coming too. I will spare the details. I HOPE that is behind me now. Back to the Astro! It has sat in my garage for the majority of this time. Short trips only to keep it moving. All of the same troubles persisted. I removed the EBCM and attempted to repair it. I have repaired many pc boards in the past. This one seemed no different. I removed the entire abs unit as I could not removed the EBCM due to rusted bolts. I also had to allocate a scan tool that would auto bleed abs brakes after re-assembly. Today was test day! Damned thing still is the same! I am highly frustrated and disappointed!! Suggestions? The only abs code I'm getting is C0236 (missing left rear speed signal). I guess I'll plan to spend the $$ for a new EBCM when I can afford it. Thanks for letting me vent. I hope that my journey will help someone from going through this.
- antispam: No
Finally!! My EBCU repair was a success! I followed the video sticky that is on this site. My left rear VSS had a broken wire above the transfer case and I made a new section of the harness (soldered) with a new Delco pigtail (from Autozone) and I no longer have any fault codes or drivability troubles. Finally! It has been a year overall with constant trouble. Perseverance pays off!! Good luck to you all on your repairs!
